[fdo-users] FDO Compile error (libxalan-c)
Traian Stanev traian.stanev at autodesk.com
Thu Oct 8 20:26:36 EDT 2009
Yes, after running make successfully, just do a
sudo make install
and you should be all done. Check /usr/local/lib (or /usr/local/lib64) to make sure there is an fdo-3.5.0 directory in there.
Traian
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of kernel_panic [sudoaptgetinstalld00d3 at gmail.com]
Sent: Thursday, October 08, 2009 7:13 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
2009/10/8, Traian Stanev <traian.stanev at autodesk.com>:
> OK, if I do a clean and then compile SDF, I get this error. Then, I ran make
> again and it disappeared... I guess it fixes itself somehow when you run
> make the second time... Weird.
> Traian
Confirmed. After running cmake for the second time, the previous noted
error did not appear, and the build was complete.
Now, FDO is completely installed? I mean, no more scripts like
buld_thirdparty and build_linux.sh
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
