[fdo-users] FDO Compile error (libxalan-c)
Traian Stanev
traian.stanev at autodesk.com
Fri Oct 9 10:44:10 EDT 2009
BTW, thanks for going through with this, I have updated the CMake readme file to say that the internal cppunit should no longer be used, so that the next person to attempt this will have an easier time.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of kernel_panic
> Sent: Thursday, October 08, 2009 7:13 PM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
> 2009/10/8, Traian Stanev <traian.stanev at autodesk.com>:
> > OK, if I do a clean and then compile SDF, I get this error. Then, I ran
> make
> > again and it disappeared... I guess it fixes itself somehow when you run
> > make the second time... Weird.
> > Traian
> Confirmed. After running cmake for the second time, the previous noted
> error did not appear, and the build was complete.
> Now, FDO is completely installed? I mean, no more scripts like
> buld_thirdparty and build_linux.sh
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
