[fdo-users] FDO Compile error (libxalan-c)
Greg Boone
greg.boone at autodesk.com
Fri Oct 9 10:46:15 EDT 2009
Yes, very much appreciated.
Are there any additional notes you can share on your usage of CMake that the other members make find useful?
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Friday, October 09, 2009 10:44 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] FDO Compile error (libxalan-c)
BTW, thanks for going through with this, I have updated the CMake readme file to say that the internal cppunit should no longer be used, so that the next person to attempt this will have an easier time.
Traian
> bounces at lists.osgeo.org] On Behalf Of kernel_panic
> Sent: Thursday, October 08, 2009 7:13 PM
> Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
> 2009/10/8, Traian Stanev <traian.stanev at autodesk.com>:
> > OK, if I do a clean and then compile SDF, I get this error. Then, I ran
> make
> > again and it disappeared... I guess it fixes itself somehow when you run
> > make the second time... Weird.
> > Traian
> Confirmed. After running cmake for the second time, the previous noted
> error did not appear, and the build was complete.
> Now, FDO is completely installed? I mean, no more scripts like
> buld_thirdparty and build_linux.sh
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
