[fdo-users] FDO Compile error (libxalan-c)
kernel_panic
sudoaptgetinstalld00d3 at gmail.com
Fri Oct 9 17:27:12 EDT 2009
> BTW, there is an fdo folder under /usr/local/fdo-3.5.0/ but its totally
> empty, shoudlnt be there fdo libraries?
> I noticed that today, while building mapguide oem (having more problems
> there, but a couple of them are already listed, Im working on the last one
> but my back es KILLING me :S), because when I was reading the documentation
> and it said that fdo should have been installed on said path by default
> (/usr/local/fdo/), I checked there and there was nothing, I remembered that
> you previously mentioned that path, re-read our post and confirmed that the
> path was correct, but there was nothing there... what happened? :p
Whoops :p:p sorry for that, I ran make install again, andd found that the
install path wasnt /usr/local/fdo-3.5.0/lib but instead it was
/usr/local/lib/fdo-3.5.0/lib/
This is different that the installed location mentioned on the official
mapguide documentation, from the install pdf:
"MapGuide requires the FDO include files and FDO libraries. If you have
installed FDO in a location
other than the default of /usr/local/fdo-3.2.3, you must use the
--with-fdo-include and --with-fdo-lib
configuration options."
So, since I never defined the location where I wanted to install fdo
(therefore, it was the default) I think that either the default install
loaction gets moved back to /usr/local/fdo... (where mapguide will
automatically look for, if not you have to pass the --with-fdo-include/lib
arguments) or mapguide should look into this path
(/usr/local/lib/fdo-3.5.0/) and the official documentation should reflect
this change.
I guess the simplest solution to this problem would be to just switch the
default installation path to mapguide's default, but thats just my two
cents, so devs will decide whats simplest and whats better.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20091009/29c96b78/attachment.html
More information about the fdo-users
