[fdo-users] FDO Compile error (libxalan-c)
Jason Birch
jason at jasonbirch.com
Mon Oct 12 00:38:35 EDT 2009
My guess would be that mapguide trunk may already account for this?
Using fdo trunk with mapguide 2.0 isn't something I'd try.
You're right, we haven't pushed a tarball for MG 2.1 yet, and svn can
sometimes take quite a few tries before making it through error-free.
If you're up to it though;
svn co http://svn.osgeo.org/mapguide/trunk/MgDev mapguide
(or something close to that)
Then if you want to compile from a non-svn tree, you can use the "svn
export" command to push a clean version to a different location for
building.
Jason
On 2009-10-11, kernel_panic <sudoaptgetinstalld00d3 at gmail.com> wrote:
>> Does the FDO include directory in /usr/local/fdo-3.5.0/inc have an /SDF
>> subdirectory with IScrollableFeatureReader.h in it?
> Remember mine is in /usr/local/lib/fdo-3.5.0/ , but no, there isnt a
> SDF (nor a SHP) folder :p
>> May be the SDF specific headers didn't get copied by the CMake "make
>> install". Those headers can be found under
>> <fdo_src_root>/Providers/SDF/Inc/.
>> However, those headers (in /SDF or /SHP) are no longer necessary -- they
>> have been unified and moved to core FDO so, they should also be available
>> under e.g. <Fdo/Commands/Feature/IScrollableFeatureReader.h>. so it's
>> probably better to fix MapGuide to get the headers from there, rather than
>> from /SDF/IScrollable...
>> Traian
> You're right, IscrollabeFeatureReader.h is under
> /usr/local/lib/fdo-3.5.0/include/Fdo/Commands/Feature/
> Now, how do I tell mapguide to look for it in this path?
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
