[fdo-users] KingOracle Provider and Linux
Riccardo Pucci
riccardo.pucci at gruppoesc.it
Tue Oct 20 09:15:01 EDT 2009
Yes the issue is unicode because the different implementation of wchar_t
type between windows and linux, there is also a minor issue with the log
api (the global variable g_LogFileName is not resolved at runtime...).
Do you know the strategy used to solve the problem? I used the OCI
Funcions OCIWideCharToMultiByte and vice versa to make string
translation, but I have introduced some memory leaks that I should
solve.. Maybe there is a better way to solve the issue.
Riccardo
Haris Kurtagic ha scritto:
> Hi Riccardo,
> I believe there are users of King.Oracle on Linux ( I am getting emails ).
> Truth is that in we are not doing GIS projects on Linux so I don't have
> direct feedback.
> I am aware of issue with unicode version and Linux, that was your issue too
> ? Something else ?
> Yes, 3.4 branch code is stable version. We are using it on couple of
> projects.
> Haris
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Riccardo Pucci
> Sent: Tuesday, October 20, 2009 12:30
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] KingOracle Provider and Linux
> Hi
> We usually use KingOrcacle provider for our MGOS projects in Windows
> environment, now we have 2 projects where we want (and we must...)to use
> MGOS with Linux and Oracle Database.
> I guess that there are not too much users, maybe no one, that use
> KingOracle under linux because I haven't find post about it in any list,
> so, before starting to ask, we set up a test environment with a CentOS
> 4.8, and we started to download and compile MGOS (2.1 brach) and FDO
> (3.4.0) from svn repository.
> After some hack to KingOracle code we finally been able to see something
> working... at least we know that to use the provider under linux is doable.
> Now i would like to ask Haris if he have planned to support linux in the
> future, and, if yes, when he has scheduled the release of a linux
> compatible version.
> More... since we have very close due date for our projects, we are
> thinking that we should modify the code to make a build of the provider
> that work only under linux. We would like to start from a stable version
> of the provider, so we need to know if the code that we download from
> the svn 3.4 branch is relative to a stable release.. (we need to use it
> with MGOS 2.1)
> Also we would like to thanks Haris and all the SL-King guys for their
> great job
> Riccardo
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
