[fdo-users] Connection problem SQL Server 2008 and FDO
psciga scigalla at battefeld.com
Thu Oct 22 05:00:52 EDT 2009
Hi Lorenzo,
I have the same problem. I have done the following in MapGuide Maestro :
creadted a new layer
selected the sqlServer FeatureSource
ignored the error message (pushed the OK-button)
saved the layer
edited the layer in XML-Editor (<FeatureName>dbo:geom</FeatureName>)
saved the changes
This runs. It's not convenient but it runs.
A Messge if the pbroblem is solved would be nice.
Regards - Peter
sorry for bad english
LFELLI wrote:
> But how i can bypass the problem in Maestro?
> Sql Server 2008 is based on GenericRdbms framework so this means that no
> one now can use Sql Server 2008 with MGOS???
View this message in context: http://n2.nabble.com/Connection-problem-SQL-Server-2008-and-FDO-tp3764539p3871138.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
