[fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2 with
AutoCAD Map 3d 2010 fails
Hermann Karl
Karl.Hermann at dornbirn.at
Mon Sep 28 06:16:29 EDT 2009
Dear List,
trying to connect to PostGIS 8.2 from AutoCAD Map 3d 2010
with connectionstring
PG:"dbname=databasename host=localhost port=5432 user=x password=y"
following error message is launched
OSGeo.FDO.Common.Execption: Connect failed:
bei OSGeo.FDO.Connections.IConnectionImp.Open()
bei
Autodesk.Gis.Map.DataConnect.Plugins.GenericProviderConnectionPlugin.but
tonLogin_Click(Object sender, EventArgs e)
in the readme of the FDO OGR-driver 3.4.0 there is following comment:
So far the OGR provider has been (successfully) tested with:
* SHP files
* MapInfo files (.TAB)
* Oracle Spatial
* ESRI personal geodatabase (.mdb)
* PostGIS (on PostgreSQL 8.1.4)
the commandlinetools ogr2ogr or ogrinfo work with this connection syntax
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090928/a0eb965a/attachment.html
More information about the fdo-users
