[fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2 with
AutoCAD Map 3d 2010 fails
Traian Stanev
traian.stanev at autodesk.com
Mon Sep 28 10:34:14 EDT 2009
The GDAL DLL that comes with FDO is not compiled with the PostGIS driver by default - try replacing it by the GDAL dll that you are using with ogr2ogr (which presumably has the driver). You will also need libpq.dll and some other supporting PostGIS dlls.
Traian
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Hermann Karl
Sent: Monday, September 28, 2009 6:16 AM
To: FDO Users Mail List
Subject: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2 with AutoCAD Map 3d 2010 fails
Dear List,
trying to connect to PostGIS 8.2 from AutoCAD Map 3d 2010
with connectionstring
PG:"dbname=databasename host=localhost port=5432 user=x password=y"
following error message is launched
OSGeo.FDO.Common.Execption: Connect failed:
bei OSGeo.FDO.Connections.IConnectionImp.Open()
bei Autodesk.Gis.Map.DataConnect.Plugins.GenericProviderConnectionPlugin.buttonLogin_Click(Object sender, EventArgs e)
in the readme of the FDO OGR-driver 3.4.0 there is following comment:
So far the OGR provider has been (successfully) tested with:
* SHP files
* MapInfo files (.TAB)
* Oracle Spatial
* ESRI personal geodatabase (.mdb)
* PostGIS (on PostgreSQL 8.1.4)
the commandlinetools ogr2ogr or ogrinfo work with this connection syntax
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090928/14754750/attachment.html
More information about the fdo-users
