AW: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2
withAutoCAD Map 3d 2010 fails
Hermann Karl
Karl.Hermann at dornbirn.at
Mon Sep 28 12:29:45 EDT 2009
Hi Traian,
Tried the gdal16.dll with all dependencies from OSGEO4W
The FDO OGR 3.4.0 connection form is not displayed
Tried the gdal16.dll with all dependencies from gdalwin32exe160
The FDO OGR 3.4.0 connection form ist displayed
PostGIS connection is not possible
Even with the gdal16.dll with all dependencies from fdo-win32-3.4.1
a PostGIS connection can not be established.
Any Idea ?
Thanks
Karl
Von: fdo-users-bounces at lists.osgeo.org
[mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von Traian Stanev
Gesendet: Montag, 28. September 2009 16:34
An: FDO Users Mail List
Betreff: RE: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2
The GDAL DLL that comes with FDO is not compiled with the PostGIS driver
by default - try replacing it by the GDAL dll that you are using with
ogr2ogr (which presumably has the driver). You will also need libpq.dll
and some other supporting PostGIS dlls.
Traian
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Hermann Karl
Sent: Monday, September 28, 2009 6:16 AM
To: FDO Users Mail List
Subject: [fdo-users] FDO OGR-Driver 3.4.0 Connecting to PostGIS 8.2 with
Dear List,
trying to connect to PostGIS 8.2 from AutoCAD Map 3d 2010
with connectionstring
PG:"dbname=databasename host=localhost port=5432 user=x password=y"
following error message is launched
OSGeo.FDO.Common.Execption: Connect failed:
bei OSGeo.FDO.Connections.IConnectionImp.Open()
bei
Autodesk.Gis.Map.DataConnect.Plugins.GenericProviderConnectionPlugin.but
tonLogin_Click(Object sender, EventArgs e)
in the readme of the FDO OGR-driver 3.4.0 there is following comment:
So far the OGR provider has been (successfully) tested with:
* SHP files
* MapInfo files (.TAB)
* Oracle Spatial
* ESRI personal geodatabase (.mdb)
* PostGIS (on PostgreSQL 8.1.4)
the commandlinetools ogr2ogr or ogrinfo work with this connection syntax
Karl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090928/9d99f29d/attachment.html
More information about the fdo-users
