[fdo-users] Re: Storing MultiCurvePolygon King Oracle Provider
Simon Pelicon simon at sl-king.com
Tue Dec 7 05:17:58 EST 2010
Hi!
I have no problems saving MultiCurvePolygons into Oracle using AutoCadMap
2010 (or 2011).
I am using KingOracle provider version 0.8.23.
My SQL for the *SDO_GEOM_METADATA_TABLE *value is:
INSERT INTO MDSYS.SDO_GEOM_METADATA_TABLE VALUES ('SIMON','VDITCH',
'GEOMETRY',MDSYS.SDO_DIM_ARRAY(MDSYS.SDO_DIM_ELEMENT('X',
-180,180,0.005),MDSYS.SDO_DIM_ELEMENT('Y', -90,90, 0.005)),4326);
simon
On Mon, Dec 6, 2010 at 9:41 AM, GISkit_Paul <paul at giskit.nl> wrote:
> Hello,
> Although Simon’s suggestion seems logical, it doesn’t solve the problem.
> Using the same Oracle table, AutoCadMap 2010 (or 2011), connecting via the
> standard Oracle Connection, I can add hand-drawn MultiCurvePolygons.
> Using AutoCadMap 2010, connecting via the King Oracle provider and manually
> adding MultiCurvePolygons causes the same error. Is the problem perhaps
> caused by the King Oracle Provider?
> Regards,
> Paul
> http://osgeo-org.1803224.n2.nabble.com/Storing-MultiCurvePolygon-King-Oracle-Provider-tp5773817p5807022.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101207/e463a815/attachment.html
More information about the fdo-users mailing list
