[fdo-users] Re: Storing MultiCurvePolygon King Oracle Provider
Brad Nesom
kidsmake6 at msn.com
Tue Dec 7 21:15:48 EST 2010
I am wondering if you poly is too large. I seem to remember some threads on
oracle spatial discussing trying to contain an entire globe dataset
incompassed by the 4326 wkid. I am way out of my element here but your -180,
-90 made me think of that.
Brad
On Tue, Dec 7, 2010 at 4:17 AM, Simon Pelicon <simon at sl-king.com> wrote:
> Hi!
> I have no problems saving MultiCurvePolygons into Oracle using AutoCadMap
> 2010 (or 2011).
> I am using KingOracle provider version 0.8.23.
> My SQL for the *SDO_GEOM_METADATA_TABLE *value is:
> INSERT INTO MDSYS.SDO_GEOM_METADATA_TABLE VALUES ('SIMON','VDITCH',
> 'GEOMETRY',MDSYS.SDO_DIM_ARRAY(MDSYS.SDO_DIM_ELEMENT('X',
> -180,180,0.005),MDSYS.SDO_DIM_ELEMENT('Y', -90,90, 0.005)),4326);
> simon
> On Mon, Dec 6, 2010 at 9:41 AM, GISkit_Paul <paul at giskit.nl> wrote:
>> Hello,
>> Although Simon’s suggestion seems logical, it doesn’t solve the problem.
>> Using the same Oracle table, AutoCadMap 2010 (or 2011), connecting via the
>> standard Oracle Connection, I can add hand-drawn MultiCurvePolygons.
>> Using AutoCadMap 2010, connecting via the King Oracle provider and
>> manually
>> adding MultiCurvePolygons causes the same error. Is the problem perhaps
>> caused by the King Oracle Provider?
>> Regards,
>> Paul
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Storing-MultiCurvePolygon-King-Oracle-Provider-tp5773817p5807022.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101207/b21f8349/attachment.html
More information about the fdo-users
