[fdo-users] Autodesk FDO provider shows only first point from multipoint geometry in Oracle!?
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Fri Dec 10 07:30:01 EST 2010
Yes, yours validates but .... I believe this one is "technically
correct" ... give it a try ....
MDSYS.SDO_GEOMETRY(2005,4326,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1,3),MDSYS
.SDO_ORDINATE_ARRAY(18.5272949231966,43.9245558053237,18.527391754093,43
.924240327095,18.5310243924313,43.9252225514267))
r,
dennis
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of mighty_duck
Sent: Friday, December 10, 2010 5:47 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Autodesk FDO provider shows only first point from
Hi all,
I have strange problem, and I really hope there is something stupid in
this
that Im not able to note :)
I have multipoint geometry in Oracle:
MDSYS.SDO_GEOMETRY(2005,4326,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1,1,3,1,1,
5,1,1),MDSYS.SDO_ORDINATE_ARRAY(18.5272949231966,43.9245558053237,18.527
391754093,43.924240327095,18.5310243924313,43.9252225514267))
I created layer in mapguide studio 2010 using autodesk fdo provider for
Oracle and it should show me three points on the map, but I can only see
the
first one :(.
Does anyone know what is the problem here, I hope this is not FDO bug,
otherwise I will need to find another approach.
Any remarks will be very important for me. If you know this issue as bug
please let me know about that.
NOTE: Im not able to switch to other FDO providers because my code
design is
fixed to autodesk fdo provider.
Thanks in advance
Minja
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-
first-point-from-multipoint-geometry-in-Oracle-tp5822675p5822675.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
Email Scan by McAfee
More information about the fdo-users mailing list
