[fdo-users] Re: Autodesk FDO provider shows only first point from
multipoint geometry in Oracle!?
mighty_duck
msiljegovic at gmail.com
Fri Dec 10 08:19:50 EST 2010
Hi dennis,
yes it works now, thx. a lot :)..but Im little bit confused now with format,
so may you explain me now meaning of
MDSYS.SDO_ELEM_INFO_ARRAY(1,1,3)
Example: I have 15 points will it be then only
MDSYS.SDO_ELEM_INFO_ARRAY(1,1,15)
or there is some other rule. Honestly I have never seen this format for
multipoint in Oracle and my potential problem now is that all current data
in oracle has old format and it seems I will need to switch it...
Thanks
Minja
On Fri, Dec 10, 2010 at 1:30 PM, djonio [via OSGeo.org] <
ml-node+5822896-739730128-217991 at n2.nabble.com<ml-node%2B5822896-739730128-217991 at n2.nabble.com>
> wrote:
> Yes, yours validates but .... I believe this one is "technically
> correct" ... give it a try ....
> MDSYS.SDO_GEOMETRY(2005,4326,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1,3),MDSYS
> .SDO_ORDINATE_ARRAY(18.5272949231966,43.9245558053237,18.527391754093,43
> .924240327095,18.5310243924313,43.9252225514267))
> r,
> dennis
> -----Original Message-----
> From: [hidden email]<http://user/SendEmail.jtp?type=node&node=5822896&i=0>
> [mailto:[hidden email]<http://user/SendEmail.jtp?type=node&node=5822896&i=1>]
> On Behalf Of mighty_duck
> Sent: Friday, December 10, 2010 5:47 AM
> To: [hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=2>
> Subject: [fdo-users] Autodesk FDO provider shows only first point from
> Hi all,
> I have strange problem, and I really hope there is something stupid in
> this
> that Im not able to note :)
> I have multipoint geometry in Oracle:
> MDSYS.SDO_GEOMETRY(2005,4326,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,1,1,3,1,1,
> 5,1,1),MDSYS.SDO_ORDINATE_ARRAY(18.5272949231966,43.9245558053237,18.527
> 391754093,43.924240327095,18.5310243924313,43.9252225514267))
> I created layer in mapguide studio 2010 using autodesk fdo provider for
> Oracle and it should show me three points on the map, but I can only see
> the
> first one :(.
> Does anyone know what is the problem here, I hope this is not FDO bug,
> otherwise I will need to find another approach.
> Any remarks will be very important for me. If you know this issue as bug
> please let me know about that.
> NOTE: Im not able to switch to other FDO providers because my code
> design is
> fixed to autodesk fdo provider.
> Thanks in advance
> Minja
> http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-<http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-?by-user=t>
> first-point-from-multipoint-geometry-in-Oracle-tp5822675p5822675.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=3>
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Email Scan by McAfee
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5822896&i=4>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-first-point-from-multipoint-geometry-in-Oracle-tp5822675p5822896.html
> To unsubscribe from Autodesk FDO provider shows only first point from
> multipoint geometry in Oracle!?, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5822675&code=bXNpbGplZ292aWNAZ21haWwuY29tfDU4MjI2NzV8MTAyMDg2MDkzNQ==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Autodesk-FDO-provider-shows-only-first-point-from-multipoint-geometry-in-Oracle-tp5822675p5823023.html
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101210/6a8164c4/attachment.html
More information about the fdo-users
