[fdo-users] KingOra Cannot Find Primary Key with Some Database
Roles
Jonio, Dennis (Aviation)
DJonio at miami-airport.com
Wed Feb 24 11:13:26 EST 2010
Crispin,
Maybe this will help.
I think I had to do the following logon script. In this case the user
profile name is "MIAR" and has access via roles only. The schema owner
in this case is " THE_SCHEMA_OWNER". Seems to work just fine for
"SELECT". I have not tried update or delete but I see no reason why it
would not if the role gives the proper permission/access. By the way, I
just set the identifier to make it easier to watch the sessions.
create or replace
TRIGGER LOGON_TRIG_MIAR
AFTER LOGON
ON MIAR.schema
DECLARE
sqlstr VARCHAR2(200) := 'alter session set current_schema =
THE_SCHEMA_OWNER';
v_user_identifier varchar2(64);
BEGIN
IF (USER = 'MIAR') THEN
execute immediate sqlstr;
SELECT 'MIAR:'|| SYS_CONTEXT('USERENV', 'IP_ADDRESS') INTO
v_user_identifier FROM dual;
dbms_session.set_identifier(v_user_identifier);
END IF;
END;
r,
Dennis
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
Crispin_at_1Spatial
Sent: Wednesday, February 24, 2010 8:06 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] KingOra Cannot Find Primary Key with Some Database
Roles
Where a KingOra connection is made to a user that has no ownership of
data
but is instead allocated access via roles and groups (not views) the
code
that finds the PKey - GetTablePkeyColumns() - passes in the "Owner" for
an
optimised query against USER_CONSTRAINTS.
Maybe it's my misunderstanding of the "Owner" -- if this the user logged
onto the DB with the connection properties then this is wrong? There is
an
entry against the ALL_CONSTRAINTS but that's a slow query.
Maybe I am creating my connection parameters wrong?
Thought I'd post here before submitting a ticket on this...
Crispin
View this message in context:
http://n2.nabble.com/KingOra-Cannot-Find-Primary-Key-with-Some-Database-
Roles-tp4625565p4625565.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
Scan by McAfee
More information about the fdo-users
