[fdo-users] Impossible to select an object on map mapguide
Dejan Gregor dejan.gregor at GMAIL.COM
Tue Jan 12 05:51:23 EST 2010
as far as I have read it work only on Materialized Views (adding a contraint
like a PM).
Can you post maybe the SQL of creating your Oracle view with the spatial
content?
Thanks!
Dejan
lunab54 wrote:
> i had the same problem but after execute this script to put anPrimary Key
> on the View it' Ok
> alter view <viewname> add constraint <constraintname> primary key
> (<columnlist>) disable novalidate;
> like in this post
>  http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg10935.html
> don't forget to refresh the data source and save it again !
> euskalmap wrote:
>> Hi,
>> It is imposible to select polyline and the tooltip display in a buffer
>> around the object, not just only mouse over the object.
>> this case if the dataconnection is associated with an oracle view.
>> we had the problem just one time with a point layer (others points layers
>> with view run well)
>> never with polygon layer now
>> if the dataconnection is associated on the oracle table directly, it run
>> well : point, polyline, polygon.
>> Thanks
>> Configuration :
>> PC Windows 2003 Server SP2
>> IIS 6
>> Mapguide OpenSource Server 2.0.2
>> Oracle 10g2
>> FDO King Oracle 0.8.10
__
Dejan Gregor, MSc
GISc Researcher and Consultant
http://www.linkedin.com/in/dgregor
View this message in context: http://n2.nabble.com/Impossible-to-select-an-object-on-map-mapguide-tp3806579p4290870.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
