[fdo-users] Obtaining Spatial Extents for large datasets in ArcSDE
Justin Beasley justin.beasley at pb.com
Fri Jul 9 08:59:05 EDT 2010
Hi All
I am experiencing a problem with using the SpatialExtents function against a FeatureClass in ArcSDE.  The FeatureClass is relatively big with 1,971,472 rows.  Executing this function never completes as memory usage ramps up to the point where I get an out of memory error.
I assume this is because the function is performing a spatial query against each geometry in the feature class.  It works fine for small datasets.
Is there a way to get to the FeatureClass spatial extents that are registered in the "Layers" table in the Oracle database that sits behind ArcSDE via FDO?
Thanks in advance
Justin
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100709/b86c3e38/attachment.html
More information about the fdo-users mailing list
