[fdo-users] Stream Free Failed exception
Zac Spitzer
zac.spitzer at gmail.com
Tue Jul 20 22:33:12 EDT 2010
which version are you using?
On 21 July 2010 09:56, Justin Beasley <justin.beasley at pb.com> wrote:
> Hi All
> I am experiencing an intermittent error when accessing tables and views in
> ArcSDE via FDO and I am wondering if this is a common exception and if
> anyone knows what could be causing it. The exception is appears to be more
> prevalent with ArcSDE views than tables but this could be a red herring.
> The exception thrown is an OSGeo.FDO.Common.Exception {“Stream free
> failed.”} by OSGeo.FDO and has the following stack trace:
> at OSGeo.FDO.Commands.SQL.ISQLDataReaderImp.ReleaseUnmanagedObject()
> at OSGeo.FDO.Runtime.Disposable.Finalize()
> There is an inner exception also of type OSGeo.FDO.Common.Exception with
> message “Unknown ArcSDE error code (965258298)”
> Thanks
> Justin
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100721/fb620ab0/attachment.html
More information about the fdo-users
