[fdo-users] Re: OSGeo.PostgreSQL.3.5 Provider Create Schema
hanko
hana.jaborova at spatialtechnology.se
Thu Jun 10 02:37:40 EDT 2010
Hi all,
1.I can create a new database 'gisdb' with OSGeo.PostgreSQL.3.5 Provider
without problems.
A schema 'public' is created with two tables 'geometry_columns' and
'spatial_ref_sys' and a view 'geography_columns'.
2.If I want to list spatial context in 'gisdb' with IGetSpatialContexts
there is none.
3.I create a new simple Feature Schema 'ShipSysSchema 'and I set
geometricProperty.SpatialContextAssociation = "3007"; //srid
When I apply my new schema I gott an exception
{"Schema ShipSysSchema has errors; cannot apply it "}
InnerException {"The spatial context name associated with geometry property
'Geom' of the feature class 'Ship' not found "}
System.Exception {OSGeo.FDO.Common.Exception}
4.I create a new spatial context srid = 3007, SWEREF99 with
ICreateSpatialContext.
A new table f_scinfo in PostGIS 'gisdb' public schema is created.
CREATE TABLE f_scinfo
f_scinfo_id bigint NOT NULL,
"3007" geometry,
CONSTRAINT public_pk_f_scinfo PRIMARY KEY (f_scinfo_id),
CONSTRAINT enforce_dims_3007 CHECK (st_ndims("3007") = 2),
CONSTRAINT enforce_srid_3007 CHECK (st_srid("3007") = (-1))
WITH (
OIDS=FALSE
5.Then I apply a Feature schema 'ShipSysSchema'.
I gott an exception
InnerException {"Error in Column
gisdb.public.geography_columns.f_geography_column: length or precision 0 is
less than minimum allowed (1) "} System.Exception
Any ideas?
Hanko
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OSGeo-PostgreSQL-3-5-Provider-Create-Schema-tp5157464p5161845.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
