[fdo-users] Not able to install PostGIS provider on AutoCAD Map
3D 2010
Tom Fukushima
tom.fukushima at autodesk.com
Wed Jun 16 13:40:38 EDT 2010
If you do install AutoCAD Map 3D 2011, all of the required PostGIS/PostgreSQL client DLLs for the supported versions of PostGIS/PostgreSQL should already be there. So Map should work "out of the box".
Cheers
Tom
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Wednesday, June 16, 2010 11:04 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] Not able to install PostGIS provider on AutoCAD Map 3D 2010
I recommend that you update to map 2011 and use the PostgreSQL Provider, which allows access to PostGIS data stores. The PostGIS provider is no longer being maintained.
Refer to the following link for info on the PostgreSQL provider.
http://trac.osgeo.org/fdo/wiki/FdoPostgreSQLNotes
Also, make sure you have the proper postgres/postgis client binary packages installed and referenced in your system path.
Greg
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Marie-Eve
Sent: Wednesday, June 16, 2010 12:29 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Not able to install PostGIS provider on AutoCAD Map 3D 2010
Hello,
I tried to add the PostGIS provider and it doesn't work.
I get that message:
Failed to load connection control for provider. Either the provider is not
installed or there was an error accessing it.
I'm using Map 3D 2010 and I tried to installed the FDO provider PostGIS 3.4.
I installed MS C++ Runtime SP1 2005.
I need some help,
Marie-Eve
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Not-able-to-install-PostGIS-provider-on-AutoCAD-Map-3D-2010-tp5187289p5187289.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
