[fdo-users] RE: Not able to install PostGIS provider on AutoCAD Map
3D 2010
Marie-Eve
marie-eve.gauthier at all-can.com
Fri Jun 18 11:13:48 EDT 2010
Hello Greg,
Thanks a lot. I installed it and it works perfectly!
Sincerely,
Marie-Eve Gauthier
All-Can Engineering & Surveys (1976) Ltd.
Phone: 403.244.2131 Ext 281
[mailto:ml-node+5187413-1456680907-568840 at n2.nabble.com]
Sent: Wednesday, June 16, 2010 11:04 AM
To: Marie-Eve
Subject: RE: Not able to install PostGIS provider on AutoCAD Map 3D 2010
I recommend that you update to map 2011 and use the PostgreSQL Provider,
which allows access to PostGIS data stores. The PostGIS provider is no
longer being maintained.
Refer to the following link for info on the PostgreSQL provider.
http://trac.osgeo.org/fdo/wiki/FdoPostgreSQLNotes
Also, make sure you have the proper postgres/postgis client binary packages
installed and referenced in your system path.
Greg
-----Original Message-----
From: [hidden email] [mailto:[hidden email]] On Behalf Of Marie-Eve
Sent: Wednesday, June 16, 2010 12:29 PM
To: [hidden email]
Subject: [fdo-users] Not able to install PostGIS provider on AutoCAD Map 3D
2010
Hello,
I tried to add the PostGIS provider and it doesn't work.
I get that message:
Failed to load connection control for provider. Either the provider is not
installed or there was an error accessing it.
I'm using Map 3D 2010 and I tried to installed the FDO provider PostGIS 3.4.
I installed MS C++ Runtime SP1 2005.
I need some help,
Marie-Eve
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Not-able-to-install-PostGIS-provider-
on-AutoCAD-Map-3D-2010-tp5187289p5187289.html
<http://osgeo-org.1803224.n2.nabble.com/Not-able-to-install-PostGIS-provider
-on-AutoCAD-Map-3D-2010-tp5187289p5187289.html?by-user=t>
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/fdo-users
[hidden email]
_____
View message @
on-AutoCAD-Map-3D-2010-tp5187289p5187413.html
To unsubscribe from Not able to install PostGIS provider on AutoCAD Map 3D
2010, click
<http://osgeo-org.1803224.n2.nabble.com/subscriptions/Unsubscribe.jtp?code=b
WFyaWUtZXZlLmdhdXRoaWVyQGFsbC1jYW4uY29tfDUxODcyODl8MTczMzA2NDMwMQ==> here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Not-able-to-install-PostGIS-provider-on-AutoCAD-Map-3D-2010-tp5187289p5195667.html
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100618/2c6bc1cc/attachment-0001.html
More information about the fdo-users
