[fdo-users] Re: Benefit to using SDE Direct Connect?
Vito Rifino
virifin at gmail.com
Mon Jun 21 03:48:15 EDT 2010
If you use the "Direct Connect" method to create a connection to an SDE
server, you don't use the SDE application server(giomgr): the SDE
application server spawns the gsrvr processes.
I use "Direct Connect" method while the SDE application server is down.
A connection string for a direct connection is (direct connection to oracle
11g):
"Server=;Instance=sde:oracle11g;Username=username;Password=password at servicename;Datastore=username"
Vito
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Benefit-to-using-SDE-Direct-Connect-tp5201408p5203249.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
