[fdo-users] Autocad map 3D 2009, bulk copy
meryem el boukhari
meryem.elboukhari at gmail.com
Mon May 3 11:46:40 EDT 2010
Hi every body, i am new user to this mailing list and i want someone to help
me please it's a little bit urgent
So i want to insert data from shapefile (ESRI) to my database in postgis
1.3.3, when using bulk copy with Autocad map 3D 2009 i get this message
"Attempted to read or write protected memory.This is often an indication
that other memory is corrupt".I granted all necesseray privileges to the
user but still the same problem.
Pls help me and thank you so much.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100503/e651ddb8/attachment.html
More information about the fdo-users
