[fdo-users] RE: Mysql provider can not be built
swap pacheco_rafael at yahoo.com.mx
Mon May 3 14:30:40 EDT 2010
Greg, thanks a lot for answering, I have run as root the export command for
enviroment as follow:
export FDO=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Fdo
export FDOUTILITIES=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Utilities
export FDOTHIRDPARTY=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Thirdparty
export FDOGDAL=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Thirdparty/gdal
export FDOMYSQL=/var/lib/mysql
About FDO version, I just tried  with 3.3.x due mgos requires 3.3.x for
installing.
The error is;
/usr/lib/mysql/libz.a(zutil.o)(.text+0x41): In function `zcalloc':
/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:304:
multiple definition of `zcalloc'
/usr/lib/mysql/libmysqlclient.a(zutil.o)(.text+0x41):/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:304:
first defined here
/usr/lib/mysql/libz.a(zutil.o)(.text+0x68): In function `zcfree':
/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:313:
multiple definition of `zcfree'
/usr/lib/mysql/libmysqlclient.a(zutil.o)(.text+0x68):/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:313:
first defined here
collect2: ld returned 1 exit status
make[2]: *** [libFdoMySQL.la] Error 1
make[2]: Leaving directory
`/root/Desktop/instxalapa/fdo/OpenSource_FDO/Providers/GenericRdbms/Src'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
make: *** [install-recursive] Error 1
I expect this information cuould be enough for you, if you need some else
please let me know.
Thank you in advance.
Rafael
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mysql-provider-can-not-be-built-tp4991252p4999363.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
