[fdo-users] RE: Mysql provider can not be built
Greg Boone
greg.boone at autodesk.com
Mon May 3 16:21:21 EDT 2010
I did a bit of googling and it seems that would are picking up multiple versions of libz. I would think that if you had only installed the developer components, libz would not be picked up from the MySQL directory. Are you building MySQL yourself? If so, you may want to adjust your MySQL compilation flags.
Refer to:
http://coding.derkeiler.com/Archive/PHP/comp.lang.php/2005-12/msg01859.html
and ...
http://coding.derkeiler.com/Archive/PHP/comp.lang.php/2005-12/msg01866.html
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of swap
Sent: Monday, May 03, 2010 2:31 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: Mysql provider can not be built
Greg, thanks a lot for answering, I have run as root the export command for
enviroment as follow:
export FDO=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Fdo
export FDOUTILITIES=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Utilities
export FDOTHIRDPARTY=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Thirdparty
export FDOGDAL=/root/Desktop/instxalapa/fdo/OpenSource_FDO/Thirdparty/gdal
export FDOMYSQL=/var/lib/mysql
About FDO version, I just tried with 3.3.x due mgos requires 3.3.x for
installing.
The error is;
/usr/lib/mysql/libz.a(zutil.o)(.text+0x41): In function `zcalloc':
/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:304:
multiple definition of `zcalloc'
/usr/lib/mysql/libmysqlclient.a(zutil.o)(.text+0x41):/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:304:
first defined here
/usr/lib/mysql/libz.a(zutil.o)(.text+0x68): In function `zcfree':
/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:313:
multiple definition of `zcfree'
/usr/lib/mysql/libmysqlclient.a(zutil.o)(.text+0x68):/export/home/my/tmp-201004061343-5.1.46-24340/rpm/BUILD/mysql-5.1.46/zlib/zutil.c:313:
first defined here
collect2: ld returned 1 exit status
make[2]: *** [libFdoMySQL.la] Error 1
make[2]: Leaving directory
`/root/Desktop/instxalapa/fdo/OpenSource_FDO/Providers/GenericRdbms/Src'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
make: *** [install-recursive] Error 1
I expect this information cuould be enough for you, if you need some else
please let me know.
Thank you in advance.
Rafael
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mysql-provider-can-not-be-built-tp4991252p4999363.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20100503/26ce7a84/attachment.html
More information about the fdo-users
