[fdo-users] Data table is not loading in AutoCAD Map 3D 2010
Mike Toews
mwtoews at gmail.com
Tue Nov 9 12:39:09 EST 2010
Are you using FDO 3.4.1? Do you have the proper metadata in
geometry_columns? Are you setting datastore to your schema where your
table is located? Are you logging in with an account that has at least
SELECT privileges to your table and geometry_columns?
My suggestion for that provider is to test with simple tables, then
try more complex if simple tests succeed. The provider is fragile and
no-longer maintained. (The newer PostgreSQL provider is much nicer, if
you have the resources.)
-Mike
On 9 November 2010 09:11, naym <r.naym at hawarit.com> wrote:
> Hello
> I have installed Postgis FDO provider in ACAD 3D Map 2010. I can login and
> connect from ACAD with database without any error. but do not get any table
> in the box. In my table "polygon_test" I have primary key, polygon data and
> I have inserted a row in geometry_columns table for polygon_test. I did
> vaccum analyze also.
> Polygon data is showing when I am connecting from Open Jump.
> Can someone help how to load the tables ?
> Best Regards
> Naym
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Data-table-is-not-loading-in-AutoCAD-Map-3D-2010-tp5721730p5721730.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
