[fdo-users] Re: Editing ArcSDE Data with Different Users
Oguz Kurt oguz at boryazilim.com
Mon Oct 11 08:31:16 EDT 2010
I realized that if i right click to a layer, click Edit Connection, then
disconnect from the connection and then reconnect to the same connection, i
can edit the features. I don't know why..
On Mon, Oct 11, 2010 at 3:18 PM, Oguz Kurt <oguz at boryazilim.com> wrote:
>  Hi,
> First of all, i need to say that i am not so familiar with AutoCAD.
> I am trying to configure AutoCAD Map3D so that different users connect to
> the ArcSDE server, gets the data and edit this data by creating new
> versions. But i encountered different errors during my tries.
> (I have an SDE user which owns the SDE tables in oracle database, and an
> ordinary user who have the permissions to create and edit data to sde
> server. Ordinary users do not have the permission to edit the default
> version, but can change the versions they create. This users are created as
> it is explained in Administering ArcSDE® for Oracle manual of ESRI)
>  I am using FDO Provider for ArcGIS Geodatabases 9.3 for establishing an
> ArcGIS connection. (I need this provider instead of ArcSDE provider since i
> am using domains in the ArcSDE data.)
> Establishing an ArcGIS connection is successful using both SDE user and
> ordinary user. *SDE user can always edit the data, no matter which version
> is loaded; while the ordinary user cannot edit any of the versions* !!!
> This is the biggest problem i have met. I am connecting with ordinary user,
> create a version and then cannot edit this version. This can be done using
> ArcSDE connection. But i have to use ArcGIS connection. Can you please help
> me with this problem.
> Oguz
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20101011/7675485f/attachment.html
More information about the fdo-users mailing list
