[fdo-users] Re: Tool for editing f_ tables in SQL 2008?
Haris Kurtagic
haris at sl-king.com
Tue Oct 26 09:36:01 EDT 2010
Now, as SQL Server is open source, perhaps code which works with those
tables could be extracted from provider.
Changed that code to work not with tables but with FDO classes and
then it could become some type of general FDO API for detailed
defining your underlaying data.
Otherwise it is not FDO API and there is no such thing as FDO-enabled
database, it is just how some provider writes additional tables which
help particular provider to describe original database tables.
Haris
On Tue, Oct 26, 2010 at 2:54 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> 1. There is no such tool at the moment to do this
> 2. FDO API has raw SQL execution option for RDBMS providers (who use f_
> tables)
> 3. Most of the f_ tables should be self-explanatory if you understand the
> FDO logical elements they are trying to represent:
> f_associationdefinition - Stores information about FDO association
> properties (foreign keys)
> f_attributedefinition - Stores information about FDO properties and the
> columns they map to
> f_attributedependencies - Not sure, but looks like more info about FDO
> association properties
> f_classdefinition - Stores information about FDO class definitions, and the
> database tables/views they map to
> f_classtype - Simple lookup table for FDO class types
> f_dbopen - Not sure
> f_options - Not sure
> f_sad - Stores metadata that is attached to FDO schema elements (Schemas,
> Classes, Properties, etc)
> f_schemainfo - Not sure
> f_schemaoptions - Not sure
> f_spatialcontext - Stores name/description of FDO spatial contexts
> f_spatialcontextgeom - Stores geometric information about which feature
> class geometries relate to which spatial context (I believe)
> f_spatialcontextgroup - Stores the remaining FDO spatial context information
> (Coordinate System, Extents, Tolerances, etc)
> So generally speaking f_classdefinition and f_attributedefinition (and
> possibly f_spatialcontextgeom too) are the main tables you want to be
> tweaking when trying to register new tables and views.
> Personally, I prefer not to have FDO-enabled databases as I have no need for
> the extra features they provide. If I wanted to reduce the attack surface, I
> can just use FDO XML configuration (Schema Overrides) for this purpose.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tool-for-editing-f-tables-in-SQL-2008-tp5673979p5674499.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
