[fdo-users] Problem with FDO King Oracle Provider - unable to load library
Zac Spitzer zac.spitzer at gmail.com
Thu Aug 18 23:06:43 EDT 2011
try using the latest version of King Oracle
http://www.sl-king.com/fdooracle/download/download.html
On Fri, Aug 19, 2011 at 10:37 AM, dblackbeer <dblackbeer at gmail.com> wrote:
> On 18 August 2011 19:09, Jan Małysiak <j.malysiak at hotmail.com> wrote:
>> Hi all,
>> I am not able to connect to Oracle database using King Oracle Provider. I'm
>> trying to establish the connection in MapGuide Maestro, but I receive a long
>> message of an error, where I think the most important part is
>> "CLNT_8_UNABLE_TO_LOAD_LIBRARY". The same appears in the error log, and the
>> same in mapagent when I try to get capabilities for King Oracle Provider.
>> I've already found several descriptions of similar problems posted by other
>> users, but unfortunately none of them solved my problem. I have added the
>> provider entry in providers.xml file, downloaded Oracle Instant Client,
>> added its path to LD_LIBRARY_PATH, checked dependencies for
>> libKingOracleProvider.so, copied required Oracle libraries to FDO/lib
>> directory, now when I run ldd command for the libKingOracleProvider.so it
>> says that all required libraries are found, nevertheless the error
>> establishing new connection still occurs.
>> I use:
>> MapGuide Open Source 2.1.0
>> FDO 3.4.0
>> MapGuide Maestro 2.1.4
>> Ubuntu 10.10
>> Oracle Instant Client 10.2.0.4
>> I'm not sure of the version of King Oracle Provider as I downloaded it in an
>> archive together with other FDO providers.
>> I would be very thankful for any help.
>> Best regards,
>> Jan Małysiak
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> King Oracle Provider it doesn't supported under linux.
> dblackbeer
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fdo-users mailing list
