[fdo-users] Problem with FDO King Oracle Provider - unable to
load library
Simon Pelicon
simon at sl-king.com
Fri Aug 19 02:29:13 EDT 2011
Hi!
We do not have King Oracle Provide for Linux.
You have to use provider that comes with the MapGuide instalation.
Try using Oracle Instant Client for Oracle 10g or 11g
Simon
On Fri, Aug 19, 2011 at 5:06 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> try using the latest version of King Oracle
> http://www.sl-king.com/fdooracle/download/download.html
> On Fri, Aug 19, 2011 at 10:37 AM, dblackbeer <dblackbeer at gmail.com> wrote:
> > On 18 August 2011 19:09, Jan Małysiak <j.malysiak at hotmail.com> wrote:
> >> Hi all,
> >> I am not able to connect to Oracle database using King Oracle Provider.
> I'm
> >> trying to establish the connection in MapGuide Maestro, but I receive a
> long
> >> message of an error, where I think the most important part is
> >> "CLNT_8_UNABLE_TO_LOAD_LIBRARY". The same appears in the error log, and
> the
> >> same in mapagent when I try to get capabilities for King Oracle
> Provider.
> >> I've already found several descriptions of similar problems posted by
> other
> >> users, but unfortunately none of them solved my problem. I have added
> the
> >> provider entry in providers.xml file, downloaded Oracle Instant Client,
> >> added its path to LD_LIBRARY_PATH, checked dependencies for
> >> libKingOracleProvider.so, copied required Oracle libraries to FDO/lib
> >> directory, now when I run ldd command for the libKingOracleProvider.so
> it
> >> says that all required libraries are found, nevertheless the error
> >> establishing new connection still occurs.
> >> I use:
> >> MapGuide Open Source 2.1.0
> >> FDO 3.4.0
> >> MapGuide Maestro 2.1.4
> >> Ubuntu 10.10
> >> Oracle Instant Client 10.2.0.4
> >> I'm not sure of the version of King Oracle Provider as I downloaded it
> in an
> >> archive together with other FDO providers.
> >> I would be very thankful for any help.
> >> Best regards,
> >> Jan Małysiak
> >> _______________________________________________
> >> fdo-users mailing list
> >> fdo-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
> > King Oracle Provider it doesn't supported under linux.
> > dblackbeer
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110819/791de14f/attachment.html
More information about the fdo-users
