[fdo-users] Problem with FDO King Oracle Provider - unable to load library
Jan Małysiak j.malysiak at hotmail.com
Fri Aug 19 03:45:32 EDT 2011
Thanks for all your replies,
@ Zac:
On SL-King website I can see only downloads for Windows, I am using Ubuntu.
@ dblackbeer and Simon:
I use provider downloaded in a packed archive from here:
http://download.osgeo.org/mapguide/releases/2.1.0/fdosdk-centos5-3.4.1.5452.tgzso
I think it should work on Linux as well. Other providers seem to work
fine, anyway all Oracle providers (I've tried OGR and ODBC) have some
problem with connection, I get 559 MgFdoException error.
Best regards,
Jan Małysiak
2011/8/19 Simon Pelicon <simon at sl-king.com>
> Hi!
> We do not have King Oracle Provide for Linux.
> You have to use provider that comes with the MapGuide instalation.
> Try using Oracle Instant Client for Oracle 10g or 11g
> Simon
> On Fri, Aug 19, 2011 at 5:06 AM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>> try using the latest version of King Oracle
>> http://www.sl-king.com/fdooracle/download/download.html
>> On Fri, Aug 19, 2011 at 10:37 AM, dblackbeer <dblackbeer at gmail.com>
>> wrote:
>> > On 18 August 2011 19:09, Jan Małysiak <j.malysiak at hotmail.com> wrote:
>> >> Hi all,
>> >> I am not able to connect to Oracle database using King Oracle Provider.
>> I'm
>> >> trying to establish the connection in MapGuide Maestro, but I receive a
>> long
>> >> message of an error, where I think the most important part is
>> >> "CLNT_8_UNABLE_TO_LOAD_LIBRARY". The same appears in the error log, and
>> the
>> >> same in mapagent when I try to get capabilities for King Oracle
>> Provider.
>> >> I've already found several descriptions of similar problems posted by
>> other
>> >> users, but unfortunately none of them solved my problem. I have added
>> the
>> >> provider entry in providers.xml file, downloaded Oracle Instant Client,
>> >> added its path to LD_LIBRARY_PATH, checked dependencies for
>> >> libKingOracleProvider.so, copied required Oracle libraries to FDO/lib
>> >> directory, now when I run ldd command for the libKingOracleProvider.so
>> it
>> >> says that all required libraries are found, nevertheless the error
>> >> establishing new connection still occurs.
>> >> I use:
>> >> MapGuide Open Source 2.1.0
>> >> FDO 3.4.0
>> >> MapGuide Maestro 2.1.4
>> >> Ubuntu 10.10
>> >> Oracle Instant Client 10.2.0.4
>> >> I'm not sure of the version of King Oracle Provider as I downloaded it
>> in an
>> >> archive together with other FDO providers.
>> >> I would be very thankful for any help.
>> >> Best regards,
>> >> Jan Małysiak
>> >> _______________________________________________
>> >> fdo-users mailing list
>> >> fdo-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> > King Oracle Provider it doesn't supported under linux.
>> > dblackbeer
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110819/7cbef8b1/attachment.html
More information about the fdo-users mailing list
