[fdo-users] Re: OGR Oracle connection problem
Jan Małysiak j.malysiak at hotmail.com
Mon Aug 22 09:59:10 EDT 2011
Hi Greg, thanks for your reply,
Sure, I checked required libraries with ldd for libOGRProvider-3.4.0.so, two
of them were missing, as I remember those were libssl.so.6 and
libcrypto.so.6. I made symbolic links to libssl.so.0.9.8 and
libcrypto.so.0.9.8 respectively. Could this be the cause of the error?
Best regards,
Jan Małysiak
W dniu 22 sierpnia 2011 14:23 użytkownik Jan Małysiak <
j.malysiak at hotmail.com> napisał:
> Hi,
> I would like to connect MapGuide OpenSource to Oracle Spatial database, I
> use Ubuntu and I've already learned that KingOracle Provider does not work
> on Linux, so now I attempt to make a connection using OSGeo FDO Provider for
> OGR. When I test connection in MapGuide Maestro I get "The remote server
> returned an error: (559) MgFdoException.: An exception occurred in FDO
> component.". For more details, I looked at error log and that's what I read:
> <2011-08-22T14:08:14>     -1388410000    MapGuide Maestro v2.1.4.5245
> 127.0.0.1    Administrator
>  Error: An exception occurred in FDO component.
>         Connect failed:
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation() line 83 file
> FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute() line 100 file
> OpTestFeatureSourceConnection.cpp
>   - MgFdoConnectionManager.Open() line 893 file FdoConnectionManager.cpp
> I've searched a lot for similar problems, but I couldn't find any working
> solution. I've tried multiple various configurations of connection
> parameters, I've tried also adding Oracle client path to LD_LIBRARY_PATH,
> but still all my attempts were unsuccessful.
> I use:
> MapGuide Open Source 2.1.0
> FDO 3.4.0
> MapGuide Maestro 2.1.4
> Ubuntu 10.10
> Oracle Instant Client 10.2.0.4
> Thank you for any help.
> Best regards,
> Jan Małysiak
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110822/88cf73fd/attachment.html
More information about the fdo-users mailing list
