[fdo-users] FDO OSGeo.OGR can read DXF Files ??
Carlos Lacerda
carlos.lacerda at gmail.com
Wed Aug 24 21:53:42 EDT 2011
Hi Frank,
Thanks for the reply.
I'm using FDO 3.5 included in MapGuide 2.2, did not know wich DXF is
supported from 3.6 version.
I try update the driver in MapGuide and return with results.
Thanks a lot.
On Wed, Aug 24, 2011 at 7:21 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Carlos,
> You have not been very specific about what version of FDO you
> are using. The DXF driver in OGR is *relatively* recent, and even
> if you are using the latest development version of FDO it may not
> include a sufficiently recent GDAL/OGR version to include the DXF.
> If you are using an older version of FDO then it is even more likely
> it does not include DXF support.
> Digging around I see FDO 3.6 does include DXF support:
> http://svn.osgeo.org/fdo/branches/3.6/Thirdparty/gdal/ogr/ogrsf_frmts/dxf/
> I see that FDO 3.5 does *not* include DXF support.
> While a bit risky and complicated, it should be possible to back port
> newer GDAL/OGR's or even just the DXF driver into an older FDO.
> Best regards,
> Frank
> On Wed, Aug 24, 2011 at 2:43 PM, Carlos Lacerda
> <carlos.lacerda at gmail.com> wrote:
>> Hi folks,
>> I searched in all sources i know, about, how to use "FDO Provider
>> OSGeo.OGR" on "MapGuide OpenSource" to read a DXF file but without
>> success :(
>> Anyone know if is possible to create a layer on MapGuide using a
>> feature source of type "FDO Provider OSGeo.OGR" ??
>> I can´t create a connection to DXF file, this provider runs ok to use
>> a Shapefile for example, but when i use a DXF file always get an
>> error.
>> Anyone has already created a DXF layer on MapGuide ???
>> Thanks a lot.
>> Sds,
>> Carlos Lacerda
>> System Architect - CIAS
>> Brasil
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
Sds,
Carlos Lacerda
Brasil
More information about the fdo-users
