[fdo-users] FDO OSGeo.OGR can read DXF Files ??
Carlos Lacerda
carlos.lacerda at gmail.com
Mon Aug 29 08:43:23 EDT 2011
Frank,,
As you have said, after replace FDO 3.6 OGR driver by FDO 3.6 DXF can
be rendered in MapGuide.
I will update FDO 3.5 to FDO 3.6 for all drivers in MapGuide.
Thanks a lot.
On Wed, Aug 24, 2011 at 10:53 PM, Carlos Lacerda
<carlos.lacerda at gmail.com> wrote:
> Hi Frank,
> Thanks for the reply.
> I'm using FDO 3.5 included in MapGuide 2.2, did not know wich DXF is
> supported from 3.6 version.
> I try update the driver in MapGuide and return with results.
> Thanks a lot.
> On Wed, Aug 24, 2011 at 7:21 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Carlos,
>> You have not been very specific about what version of FDO you
>> are using. The DXF driver in OGR is *relatively* recent, and even
>> if you are using the latest development version of FDO it may not
>> include a sufficiently recent GDAL/OGR version to include the DXF.
>> If you are using an older version of FDO then it is even more likely
>> it does not include DXF support.
>> Digging around I see FDO 3.6 does include DXF support:
>> http://svn.osgeo.org/fdo/branches/3.6/Thirdparty/gdal/ogr/ogrsf_frmts/dxf/
>> I see that FDO 3.5 does *not* include DXF support.
>> While a bit risky and complicated, it should be possible to back port
>> newer GDAL/OGR's or even just the DXF driver into an older FDO.
>> Best regards,
>> Frank
>> On Wed, Aug 24, 2011 at 2:43 PM, Carlos Lacerda
>>> Hi folks,
>>> I searched in all sources i know, about, how to use "FDO Provider
>>> OSGeo.OGR" on "MapGuide OpenSource" to read a DXF file but without
>>> success :(
>>> Anyone know if is possible to create a layer on MapGuide using a
>>> feature source of type "FDO Provider OSGeo.OGR" ??
>>> I can´t create a connection to DXF file, this provider runs ok to use
>>> a Shapefile for example, but when i use a DXF file always get an
>>> error.
>>> Anyone has already created a DXF layer on MapGuide ???
>>> Thanks a lot.
>>> Sds,
>>> Carlos Lacerda
>>> System Architect - CIAS
>>> Brasil
>>> fdo-users mailing list
>>> fdo-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Software Developer
> Sds,
> Carlos Lacerda
> Brasil
Sds,
Carlos Lacerda
Brasil
More information about the fdo-users
