[fdo-users] FDO OSGeo.OGR can read DXF Files ??
Greg Boone greg.boone at autodesk.com
Mon Aug 29 08:49:08 EDT 2011
I am not sure you can simply move from FDO 3.5 to 3.6 and not move to the newer version of MapGuide as well. There could be DLL compatibility issues. You should check with the MapGuide community to verify and mixing of development/runtime environments.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Carlos Lacerda
Sent: Monday, August 29, 2011 8:43 AM
To: FDO Users Mail List
Subject: Re: [fdo-users] FDO OSGeo.OGR can read DXF Files ??
Frank,,
As you have said, after replace FDO 3.6 OGR driver by FDO 3.6 DXF can be rendered in MapGuide.
I will update FDO 3.5 to FDO 3.6 for all drivers in MapGuide.
Thanks a lot.
On Wed, Aug 24, 2011 at 10:53 PM, Carlos Lacerda <carlos.lacerda at gmail.com> wrote:
> Hi Frank,
> Thanks for the reply.
> I'm using FDO 3.5 included in MapGuide 2.2, did not know wich DXF is
> supported from 3.6 version.
> I try update the driver in MapGuide and return with results.
> Thanks a lot.
> On Wed, Aug 24, 2011 at 7:21 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Carlos,
>> You have not been very specific about what version of FDO you are
>> using.  The DXF driver in OGR is *relatively* recent, and even if you
>> are using the latest development version of FDO it may not include a
>> sufficiently recent GDAL/OGR version to include the DXF.
>> If you are using an older version of FDO then it is even more likely
>> it does not include DXF support.
>> Digging around I see FDO 3.6 does include DXF support:
>> http://svn.osgeo.org/fdo/branches/3.6/Thirdparty/gdal/ogr/ogrsf_frmts
>> /dxf/
>> I see that FDO 3.5 does *not* include DXF support.
>> While a bit risky and complicated, it should be possible to back port
>> newer GDAL/OGR's or even just the DXF driver into an older FDO.
>> Best regards,
>> Frank
>> On Wed, Aug 24, 2011 at 2:43 PM, Carlos Lacerda
>>> Hi folks,
>>> I searched in all sources i know, about, how to use "FDO Provider
>>> OSGeo.OGR" on "MapGuide OpenSource" to read a DXF file but without
>>> success :(
>>> Anyone know if is possible to create a layer on MapGuide using  a
>>> feature source of type "FDO Provider OSGeo.OGR" ??
>>> I can´t create a connection to DXF file, this provider runs ok to
>>> use a Shapefile for example, but when i use a DXF file always get an
>>> error.
>>> Anyone has already created a DXF layer on MapGuide ???
>>> Thanks a lot.
>>> Sds,
>>> Carlos Lacerda
>>> System Architect - CIAS
>>> Brasil
>>> fdo-users mailing list
>>> fdo-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com light and sound - activate the windows |
>> http://pobox.com/~warmerdam and watch the world go round - Rush    |
>> Geospatial Software Developer
> Sds,
> Carlos Lacerda
> Brasil
Sds,
Carlos Lacerda
Brasil
More information about the fdo-users mailing list
