[fdo-users] SDE and slow multi-geometries
Oyvind Idland
oyvind.idland at gmail.com
Wed Feb 16 10:53:13 EST 2011
Hello,
I have been looking into an issue that was brought up here earlier. Turns
out that the SDE API
is slower than cold molassis when using SE_shape_get_num_points() on
multipart geometries.
I did some experimentation using the index tables returned from
SE_shape_get_all_points()
directly. The total processing speed on my dataset went from roughly 20 secs
down to less than
1 sec. There are several huge polygons with 200+ holes in them, and
multilines.
Why the native SDE API is so slow is a mystery, those indices should not
require heavy
calculation.
The code is experimental so far, but when I finish writing the code, I can
submit a patch
if desired.
-- Øyvind Idland
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110216/601e80c7/attachment.html
More information about the fdo-users
