[fdo-users] RE: Which GML version is supported by FDO 3.5.0
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Fri Jan 14 03:40:14 EST 2011
The provider is SHP.
I have the same code in two .NET projects referencing FDO 3.5 and 3.6 so I
end up with a 3.5 exe and a 3.6 exe so I know the application is the same
and I am referencing the same SHP file.
A query to get spatial context returns "Default" on the SHP file in 3.5 and
3.6 (there is no .PRJ file with the SHP)
So it looks like the previous 3.5 XML provider is setting the srs to
EPSG:4326 - through some rule?
The 3.6 provider is preserving the default name.
I am no GML expert so I couldn't say which is a better interpretation where
there is no spatial context found.
I'd be more interested in a clarification if NULL properties should be
absent or with empty XML tags.
Thanks for updating the thread - Crispin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Which-GML-version-is-supported-by-FDO-3-5-0-tp5906711p5921022.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
