[fdo-users] Re: Re:
Ray ray.wu at efacec.com
Fri Mar 4 17:47:32 EST 2011
Jackie,
Using your strategy, the "Attemp to read/write to protected memory" issue
became better and it actually improved the performance for importing big
dataset. However, when I test with a very big dataset (10 hr importing
time), I got a new problem "(dbgql_define_rdb) Memory Error when call
FDOCmd.Execute()" which I posted on this website a few weeks ago. If I don't
use the dictionary strategy, the memory error is not there.
I wonder if the new memory issue could be related with memory cleanup of FDO
objects. I suspect it might be related with GeometryValue cleanup. When I
tried to use GeometryValue.Dispose(), I got "Attemp to read/write to
protected memory" again. I wonder how do you clean GeometryValue object when
using dictionary strategy and set geometry for each new object?
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Attemp-to-read-write-to-protected-memory-exception-when-reusing-fdo-command-tp5766778p6090344.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
