[fdo-users] RE: Re:
Ray
ray.wu at efacec.com
Fri Mar 4 17:50:09 EST 2011
[mailto:ml-node+6090344-1756139584-304287 at n2.nabble.com]
Sent: Friday, March 04, 2011 5:48 PM
To: Ray Wu
Subject: Re: Re:
Jackie,
Using your strategy, the "Attemp to read/write to protected memory"
issue became better and it actually improved the performance for
importing big dataset. However, when I test with a very big dataset (10
hr importing time), I got a new problem "(dbgql_define_rdb) Memory Error
when call FDOCmd.Execute()" which I posted on this website a few weeks
ago. If I don't use the dictionary strategy, the memory error is not
there.
I wonder if the new memory issue could be related with memory cleanup of
FDO objects. I suspect it might be related with GeometryValue cleanup.
When I tried to use GeometryValue.Dispose(), I got "Attemp to read/write
to protected memory" again. I wonder how do you clean GeometryValue
object when using dictionary strategy and set geometry for each new
object?
Thanks.
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1803224.n2.nabble.com/Attemp-to-read-write-to-protected
-memory-exception-when-reusing-fdo-command-tp5766778p6090344.html
To unsubscribe from "Attemp to read/write to protected memory" exception
when reusing fdo command, click here
<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=u
nsubscribe_by_code&node=5766778&code=cmF5Lnd1QGVmYWNlYy5jb218NTc2Njc3OHw
xMTE1NDc4ODI2> .
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Attemp-to-read-write-to-protected-memory-exception-when-reusing-fdo-command-tp5766778p6090355.html
Sent from the FDO Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20110304/f0f560b8/attachment.html
More information about the fdo-users
