[fdo-users] Re: Memory issue with FDO IInsert and workaround
Ray
ray.wu at efacec.com
Tue Apr 10 09:54:57 EDT 2012
Thanks Jackie for your input.
For #1: I simply call the following to do the insertion:
IInsertCmd.Execute().
Instead of the above, should I do the following?
fdoReader.close()
Btw, I reuse the same IInsertCmd for all the insertions.
For #2, I use the former approach because I have to insert for a number of
featureclasses and each of them have a dozen of properties. Instead of
caching all the propertyvalues for each the featureclasses which will be
hundred of propertyvalues in total, I wrote some generic code (a dozen lines
of code) which works for all feature classes. So I did new propertyvalue for
each record, but I dispose them after each insertion.
So FDO can not use fragmented memory? I called ODP.net which doesn't seem to
be a problem.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Memory-issue-with-FDO-IInsert-and-workaround-tp4717196p4752522.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
