[fdo-users] Re: Memory issue with FDO IInsert and workaround
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Tue Apr 10 10:08:34 EDT 2012
Hi Ray,
You should use the insert command like below:
using (FdoIFeatureReader fdoReader=IInsertCmd.Execute())
fdoReader.Close();
Moreover in your code you should avoid calling FDO objects like:
FdoObj.Acollection.Add(*);
You should use it liek below:
collection = FdoObj.Acollection
collection.Add(*);
You can also try to call Dispose (or add using blocks) on new FDO objects to avoid GC to free them when is too late.
Regards,
Romy
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] on behalf of Ray [ray.wu at efacec.com]
Sent: Tuesday, April 10, 2012 9:54 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: Memory issue with FDO IInsert and workaround
Thanks Jackie for your input.
For #1: I simply call the following to do the insertion:
IInsertCmd.Execute().
Instead of the above, should I do the following?
fdoReader.close()
Btw, I reuse the same IInsertCmd for all the insertions.
For #2, I use the former approach because I have to insert for a number of
featureclasses and each of them have a dozen of properties. Instead of
caching all the propertyvalues for each the featureclasses which will be
hundred of propertyvalues in total, I wrote some generic code (a dozen lines
of code) which works for all feature classes. So I did new propertyvalue for
each record, but I dispose them after each insertion.
So FDO can not use fragmented memory? I called ODP.net which doesn't seem to
be a problem.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Memory-issue-with-FDO-IInsert-and-workaround-tp4717196p4752522.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
