[fdo-users] OGR provider 3.4,
AutoCAD Map 2010 and ESRI personal geodatabase
Bassler, Brian CTR NAVFAC MIDLANT, GIS
brian.bassler.ctr at navy.mil
Mon Apr 16 14:09:46 EDT 2012
Greetings,
We have been experimenting with the OGR provider for AutoCAD Map 2010 and have found something we can't explain. From ESRI ArcMap we export the same feature set as a shapefile, as a cad file and as a personal geodatabase. Then in AutoCAD, we open the cad file, use the SHP provider to attach the shapefile and the OGR provider (v 3.4) to attach the personal geodatabase. Theoretically, we should see 3 instances of each feature in one form or another . . . right?
No. When we attach to the personal geodatabase and add our feature to the map we get get the message "failed to cache features" and "geometry is null". In this particular test set, are 6 features which should have appeared but only 4 did. The table data does include records for all 6.
The shapefile and cad file show the features as they should.
Any ideas what causes the two error messages and two features to be missing?
Thanks,
Brian C. Bassler
MIDLANT GeoReadiness Center
9742 Maryland Ave, Bldg Z-140, Rm 103
Norfolk, VA 23511
Ph: (757) 341-0277
Email: brian.bassler.ctr at navy.mil
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-users/attachments/20120416/5362bcde/smime.bin
More information about the fdo-users
