[fdo-users] Error in executing
OSGeo.FDO.Commands.Feature.ISelectImp.Execute (Spatial query)
Ray
ray.wu at efacec.com
Mon Mar 12 10:47:34 EDT 2012
I am running data query on a large data set using FDO ISelect command. Here
are part of the code snippet:
iFeatureSelect =
oFDOConnection.CreateCommand(Commands.CommandType.CommandType_Select)
iFeatureSelect.SetFeatureClassName(sFeatureClass)
iFeatureSelect.Filter = GetSpatialFilter(sFeatureClass, dBoundingBox)
iFeatureSelect.Filter = iFeatureSelect.Filter.Combine(iFeatureSelect.Filter,
OSGeo.FDO.Filter.BinaryLogicalOperations.BinaryLogicalOperations_And,
"VER='" + version + "'")
I got the following exception information:
Ora-29902: Error in executing ODCIIndexStart() routine
Ora-21780: Maximum number of object durings exceeded
Ora-06512: at "MDSYS.SDO_INDEX_METHOD_10I", LINE 369 at
OSGeo.FDO.Commands.Feature.ISelectImp.Execute()
The exception seems to happen randomly and occassionaly it may run
successfully for the entire data set.
I wonder if any one got same exception like me?
I would like to forward the question to ORACLE as well. But I need to know
what ORACLE API calls do FDO implemenation invoke: does FDO call ODP.NET or
ODBC or sth else so that I can forward the question to correct ORACLE
group/department.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-in-executing-OSGeo-FDO-Commands-Feature-ISelectImp-Execute-Spatial-query-tp4570379p4570379.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
