[fdo-users] Error in executing OSGeo.FDO.Commands.Feature.ISelectImp.Execute (Spatial query)
Greg Boone greg.boone at autodesk.com
Mon Mar 12 13:18:02 EDT 2012
Before sending any request to Oracle, you may want to search the Oracle forums for similar complaints.
Such as...
https://forums.oracle.com/forums/thread.jspa?threadID=709247
It could possibly be a data driven issue.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Ray
Sent: Monday, March 12, 2012 10:48 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Error in executing OSGeo.FDO.Commands.Feature.ISelectImp.Execute (Spatial query)
I am running data query on a large data set using FDO ISelect command. Here are part of the code snippet:
iFeatureSelect =
oFDOConnection.CreateCommand(Commands.CommandType.CommandType_Select)
iFeatureSelect.SetFeatureClassName(sFeatureClass)
iFeatureSelect.Filter = GetSpatialFilter(sFeatureClass, dBoundingBox) iFeatureSelect.Filter = iFeatureSelect.Filter.Combine(iFeatureSelect.Filter,
OSGeo.FDO.Filter.BinaryLogicalOperations.BinaryLogicalOperations_And,
"VER='" + version + "'")
I got the following exception information:
Ora-29902: Error in executing ODCIIndexStart() routine
Ora-21780: Maximum number of object durings exceeded
Ora-06512: at "MDSYS.SDO_INDEX_METHOD_10I", LINE 369 at
OSGeo.FDO.Commands.Feature.ISelectImp.Execute()
The exception seems to happen randomly and occassionaly it may run successfully for the entire data set.
I wonder if any one got same exception like me?
I would like to forward the question to ORACLE as well. But I need to know what ORACLE API calls do FDO implemenation invoke: does FDO call ODP.NET or ODBC or sth else so that I can forward the question to correct ORACLE group/department.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-in-executing-OSGeo-FDO-Commands-Feature-ISelectImp-Execute-Spatial-query-tp4570379p4570379.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
