[fdo-users] Visual data filtering
Zdeněk Neustupa
zdenek.neustupa at centrum.cz
Thu Mar 15 07:44:11 EDT 2012
Hello.
I am quite new to FDO so please be patient with me.
I have a question which could seem little silly.
I enclose a code snippet which I use to load data from SHP files during an
opening of DWG file to which the SHP data is onnected.
What I need is:
If I SELECT data using a select command, I need to show this result in
AutoCAD Civil 3D as well (visually).
Is there anything in FDO what I can use to do this, or is it no longer a
part of FDO?
Thank you very much for your answer.
Zdenek Neustupa
public void LoadData(string featClass)
string name =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDo
cument.Name;
string myShpFileOrDirectory = name.Remove(name.LastIndexOf('\\') + 1) +
"geo_2011";
OSGeo.FDO.IConnectionManager mConnMgr =
OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager();
OSGeo.FDO.Connections.IConnection mProvConn =
mConnMgr.CreateConnection("OSGeo.SHP");
OSGeo.FDO.Connections.IConnectionInfo connInfo = mProvConn.ConnectionInfo;
OSGeo.FDO.Connections.IConnectionPropertyDictionary connPropDict =
connInfo.ConnectionProperties;
connPropDict.SetProperty("DefaultFileLocation", myShpFileOrDirectory);
mProvConn.Open();
OSGeo.FDO.Commands.Feature.ISelect selCmd =
(OSGeo.FDO.Commands.Feature.ISelect)mProvConn.CreateCommand(OSGeo.FDO.Comman
ds.CommandType.CommandType_Select);
selCmd.SetFeatureClassName(featClass);
selCmd.SetFilter("CAO>45.0");
OSGeo.FDO.Commands.Feature.IReader myReader = selCmd.Execute();
while (myReader.ReadNext())
// put SELECT result to data grid and show it in Win Form to user
myReader.Close();
myReader.Dispose();
mProvConn.Close();
mProvConn.Dispose();
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120315/f817682e/attachment.html
More information about the fdo-users
