[fdo-users] Re: Visual data filtering
Jackie Ng jumpinjackie at gmail.com
Thu Mar 15 08:52:57 EDT 2012
Civil3D should have the same FDO data connect functionality as AutoCAD Map3D.
So you should just be able to follow the link below to bring a SHP file into
the current drawing that can be filtered and whose attribute data can be
displayed in a grid with the Data Table:
http://docs.autodesk.com/CIV3D/2012/ENU/filesMUG/GUID-9E2597F9-9DA8-4825-B62D-8EB21BAD423-131.htm
This procedure requires no programming
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Visual-data-filtering-tp4620958p4621200.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
