[fdo-users] Re: Visual data filtering
Zdeněk Neustupa
zdenek.neustupa at centrum.cz
Thu Mar 15 10:08:13 EDT 2012
Thank you.
Yes I know about this functionality. But I need to do this exact thing
programmatically.
Is there any possibility?
Zdenek Neustupa
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, March 15, 2012 1:53 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: Visual data filtering
Civil3D should have the same FDO data connect functionality as AutoCAD
Map3D.
So you should just be able to follow the link below to bring a SHP file into
the current drawing that can be filtered and whose attribute data can be
displayed in a grid with the Data Table:
http://docs.autodesk.com/CIV3D/2012/ENU/filesMUG/GUID-9E2597F9-9DA8-4825-B62
D-8EB21BAD423-131.htm
This procedure requires no programming
- Jackie
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Visual-data-filtering-tp4620958p4621200.
html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
