[fdo-users] Re: Visual data filtering
Partha P. Sarkar
partha.sarkar at autodesk.com
Thu Mar 15 11:37:18 EDT 2012
Hi Zdenek,
FDO API will work in Civil 3D also as it's built on top of Map 3D. Try using MgFeatureQueryOptions object.
Try the following code snippet -
AcMapMap currentMap = AcMapMap.GetCurrentMap();
MgLayerCollection layers = currentMap.GetLayers();
MgLayerBase layer = layers.GetItem("Roads");
MgFeatureService fs = AcMapServiceFactory.GetService(MgServiceType.FeatureService) as MgFeatureService;
string fsId = layer.GetFeatureSourceId();
string className = layer.GetFeatureClassName();
MgFeatureQueryOptions query = new MgFeatureQueryOptions();
query.SetFilter("FeatId = 5");
MgResourceIdentifier resId = new MgResourceIdentifier(fsId);
MgFeatureReader featureReader = fs.SelectFeatures(resId, className, query);
Hope this helps.
Thanks,
Partha Sarkar
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Zdenek Neustupa
Sent: Thursday, March 15, 2012 7:38 PM
To: 'FDO Users Mail List'
Subject: RE: [fdo-users] Re: Visual data filtering
Thank you.
Yes I know about this functionality. But I need to do this exact thing programmatically.
Is there any possibility?
Zdenek Neustupa
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, March 15, 2012 1:53 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Re: Visual data filtering
Civil3D should have the same FDO data connect functionality as AutoCAD Map3D.
So you should just be able to follow the link below to bring a SHP file into the current drawing that can be filtered and whose attribute data can be displayed in a grid with the Data Table:
http://docs.autodesk.com/CIV3D/2012/ENU/filesMUG/GUID-9E2597F9-9DA8-4825-B62
D-8EB21BAD423-131.htm
This procedure requires no programming
- Jackie
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Visual-data-filtering-tp4620958p4621200.
html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
fdo-users at lists.osgeo.org<mailto:fdo-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120315/25ed50e8/attachment-0001.html
More information about the fdo-users
