[fdo-users] building FDO source code on Windows
Snehal Joshi
snehal.joshi at gmail.com
Tue May 8 23:00:10 EDT 2012
Hi Orest,
Many thanks for your help. I've one more follow-up question -
Would the ArcSDE SDK installer also provide the SDE client libraries
needed at run-time? (I'm assuming these are sg.dll, sde.dll, and pe.dll).
Snehal
On Tue, May 8, 2012 at 7:17 PM, Orest Halustchak <
orest.halustchak at autodesk.com> wrote:
> Hi,****
> It uses the C API, which you can get from the ArcSDE SDK. You don’t need
> the ArcSDE server just to build the provider, but you will need the SDE
> client libraries to run the provider.****
> Orest.****
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Snehal Joshi
> *Sent:* Tuesday, May 08, 2012 1:51 PM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] building FDO source code on Windows****
> Hi All,
> I am trying to compile FDO source code on Windows. From the build
> instructions, I figured I'd need to get ArcSDE SDK. I see there are two
> choices for this - the C-API or the Java SDK. I plan to build the FDO
> binaries to be used in C++ application. So, I'm assuming I could use the
> C-API. Is that a valid assumption. Also, do I need to have any additional
> ArcGIS/ArcSDE components installed the machine I use to build FDO code. I
> don't have ArcGIS/ArcSDE Server or Oracle on it currently. I have been
> struggling to get more information on this, and will greatly appreciate any
> pointers.
> Many thanks!
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120508/7058f5e9/attachment.html
More information about the fdo-users
