[fdo-users] building FDO source code on Windows
Orest Halustchak
orest.halustchak at autodesk.com
Tue May 8 20:17:50 EDT 2012
It uses the C API, which you can get from the ArcSDE SDK. You don't need the ArcSDE server just to build the provider, but you will need the SDE client libraries to run the provider.
Orest.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Snehal Joshi
Sent: Tuesday, May 08, 2012 1:51 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] building FDO source code on Windows
Hi All,
I am trying to compile FDO source code on Windows. From the build instructions, I figured I'd need to get ArcSDE SDK. I see there are two choices for this - the C-API or the Java SDK. I plan to build the FDO binaries to be used in C++ application. So, I'm assuming I could use the C-API. Is that a valid assumption. Also, do I need to have any additional ArcGIS/ArcSDE components installed the machine I use to build FDO code. I don't have ArcGIS/ArcSDE Server or Oracle on it currently. I have been struggling to get more information on this, and will greatly appreciate any pointers.
Many thanks!
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120509/da68ec86/attachment.html
More information about the fdo-users
